Zenith CruZer & Sonex Logs
Date:  1-24-2021
Number of Hours:  1.70
Manual Reference:  n/a
Brief Description:  Install oil pump
Continued cleanup of the accesory case; Used thinner to remove some overspary. Gave a second coat where needed on the oil sump.
Installed the oil pump gears after lubing generously. Installed the cover bolts finger tight. Need to be torqued, but I'm confused if there need to be washers under the bolt heads. I don't have any in the parts bag I saved everything, but the IPC calls them out.
Iasked online to see what the world thinks. I'm OK with using washers, but just want to ensure there's not an interference issue with the cam gear.
