Zenith CruZer & Sonex Logs
Date:  11-21-2020
Number of Hours:  1.60
Manual Reference:  n/a
Brief Description:  Finish right vinyl decals; started left side
Put the plane out in the sun to help dissipate the remaining bubbles in the vinyl. Worked to manually fit around the rivets a few times.
Measured the key points on the right side; placed the left side grapnics in place, and adjusted several times. Taped the front portion in place, then added the aft section.
Copyright © 2001-2021 Matronics. All Rights Reserved.
