Brief Description: Add connectors to stick grip harness
Borrowed a molex crimper from my neighbor and attached terminal ends to 8 wires from the stick grimp: power, comm ground, fuse ground, PTT, trim up, trim down, memorry channel select, and active/standby swap.
Added 8 crimp terminals to the connecting wires from the comm , power and ground, and two trim control wires.
