Brief Description: More wire labels & drill the panel
Obtained an additional spool of heat shrink tubing labels today that was larger in diaimeter. This let me label the coax wires as well as some of the thicker, mult-conductor cables.
I drilled all holes for switches, breakers, and trim controls. Each breaker "type" had a different diameter hole. C'mon, Tyco!! Drilled for all push-pull cables as well.
