Zenith CruZer & Sonex Logs
Date:  7-6-2020
Number of Hours:  1.70
Manual Reference:  n/a
Brief Description:  Finish fuselage wiring
A lot of time in the hell hole today; was soaked; only 85% humidity, though.... :-(
I ran the 3 wire harness from the magnetometer over to the left fuselage side wall and fastened with Cobra mounts alongside the ELT location. Note that after this step, I went back and placed wire loom over the loose wires to keep them bundled.
Now that the final wires are installed, I bundled the left and right side of the fuselage wires into harnesses and secured them with wire loom and zip ties.
I installed 2 of the 4 L angles that go between the firewall and the panel front in order to set the "distance" betwen the two.
Drilled the console top for the location of the trimp control source select. This was prep for priming and painting this portion of the console.
