Zenith CruZer & Sonex Logs
Date: 7-1-2020
Number of Hours: 1.10
Manual Reference: n/a
Brief Description: Fab GPS antenna shelf / rivet seat back stops / fa
Small unrelated tasks, easy to complete.
First up was that since I have 2 gps antennas, I really didn't want them sitting on the top of the panel. I fabricated a shelf out of a single piece of scrap alumniium; bent the flanges, drilled pilot holes, and drilled onto firewall. Have not yet riveted.
I received my new supply of AS5 (stainless steel) rivets today, so I was able to rivet the seat back stops to the seat pans that will be mounted to the sliding seat mechanisms.
Lastly, the magnetometer does not *have* to be installed flat, but I decided to make a small mounting tray. The magnetometer must be mounted with brass or nylon fasteners, and I really dind't want nylon hardware extending below the fuselage. I figure the slight slope on the mount will allow room for the hardware,and the mount can be riveted to the airframe with aluminum rivets.
shelf for gps antennae
seat belt stops
magnetometer shelf, unbent
