Zenith CruZer & Sonex Logs
Date:  6-21-2020
Number of Hours:  1.60
Manual Reference:  n/a
Brief Description:  Add cabin heat cable bracket / rivet vertical post
Productive day working punch list items.
I had previously installed the cabin heat valve and baffle; today I installed the bracket supporting the cable housing for the cable to reach the valve.
Found the GRT magnetometer wiring instructions and inserted the wiring pins into the harness. I'm going to install this aft of the hell hole.
I had previously installed everything (?) into the main structural vertical channels at the front of the aft fuselage. Figured I'd wait a few months to make sure I couldn't think of anything else to put in there. Finally buttoned 'em up.
Removed the brake hose gear leg covers. Removed labels and painted with primer.
