Zenith CruZer & Sonex Logs
Date:  6-2-2020
Manual Reference:  C75-CCO-1A
Brief Description:  Nutplates for right side of center console
No pics.
Had to do a bit of rework in that I forgot the center horizontal piece had nutplates as well as the L angle sides. Removed L & R upper nutplates.
Installed nutplates on all remaining locations on the center console horizontal section.
Up-drilled the un-nutplated holes to allow some "wiggle room" when doing final install. This is for access only; not structural.
Installed nutplates along the botttom L angle for the console side skin. Test-screwed each after riveting.
Riveted the right side vertical L angle to the front seat support.
