Zenith CruZer & Sonex Logs
Date:  5-1-2020
Number of Hours:  2.70
Manual Reference:  C75-NA-2
Brief Description:  Completion tasks right door; final trim & fittings
Went back and forth between doors; read carefully.
Did some more touchup paint on the right door. The on and off turing trim just tore stuff up.
Finished plexi trim on left door; took about 3-4 iterations. While the glass was still on the door frame, positioned and pilot-drilled the center door latch mount to the door frame. updrilled, deburred, and painted.
Left door, enlarged glass rivet holes to 3/16" to allow for thermal expansion. Deburred. Filed glass edges smooth.
Shot some paint on left door in just a small area; will do more later.
On right door, installed the hardware for the front door latch. Located, pilot drilled, updrilled, and riveted the door-side balljoint that connects the door to the pneumatic cylinder to hold the door open. Touched up paint on this door as well.
right door cylinder ball joint
right door front latch
left door center latch
Copyright © 2001-2021 Matronics. All Rights Reserved.
