Zenith CruZer & Sonex Logs
Date:  4-14-2020
Number of Hours:  1.40
Manual Reference:  C75-NA-2
Brief Description:  Trim right side door plexiglass
Not done yet, but great progress.
Used a cutoff wheel in my dremel to trim-away the larger pieces of the glass overhang, then multiple passes with a belt sander to finesse the fit. Front and rear edges just about done - just a skoatch more off a high spot on each side. Most of the bottom is trimmed, but will require a bit more material removal.
Copyright © 2001-2021 Matronics. All Rights Reserved.
