Basically spent the afternoon test-drawing a fuel line bypass checkvalve installation. I was originally going to use the supplied pump, but then saw issues with pumps failing and blocking the flow. I then decided to have no pump, and rely on gravity flow just like Cessnas. I finally decided to keep the pump, but add a bypass loop with a checkvalve. The "normal" gravity flow will all be straight line thru the fittings, with the pump coming off a tee on each end of the checkvalve.
Next up was trying to find the fittings for my combinations of barbed rubber line, device fittings with NPT threads, gascolator, and shutoff valve. There's a LOT of fittings out there....
