Zenith CruZer & Sonex Logs
Date:  2-17-2020
Number of Hours:  1.80
Manual Reference:  n/a
Brief Description:  Finish line routing / hole trim on front seat supp
Marked and drilled two new 5/16" holes for the reamining 2 nylon tubes that extend from the baggage compartment uip to the panel. I also hogged-out the front hole in order to support the fuel lines. Installed the grommet edging to prevent chafing.
Installed elevator control onto the main yoke and tightened AN3 bolt.
Installed rudder cables onto rudder pedals. Did not install cotter pins on the castle nuts because that has to wait for the rudder to be installed.
