Zenith CruZer & Sonex Logs
750 Cruzer
n/a
Install Right Side Fuel & electric lines
Had back issues the last few weeks; very painful. Finally had some relief today so got some stuff done.
Trimmed top and bottom of internal L angle reinforcing structure just as I did for the left side.
Several attempts were made to route the fuel and electric lines just right to reduce compression and abrasion.
Installed the lower fuel drain on the right side. Tightened. Will need to safety-wire.
Following the fuel lilne routing, iz mixed up some JB Weld and installed the left and right brake line tubes thru the floor.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
