Zenith CruZer & Sonex Logs
750 Cruzer
n/a
Seat belt brackets / seat rails / parts prep
Took longer than one would think.
Clamped outboard right seat belt bracket in place and drilled pilot holes. Up-drilled to #20 size for A5 rivets. Deburred.
Repeated on right side.
Riveted the outboard lower seat pan-to-firewall connections.
Cleaned the floor plan from several past riveting events - was getting too cluttered with drill chips.
De-labeled the lower door sill reinforcements and upper door hinges. Measured hinges against the upper sill. Will have to cut to fit.
750 Cruzer Home
2322
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
02 - Wing Spars
03 - Wings
76
389
04 - Flaps & Aileron
116
278
Systems
389
Sonex Home
Copyright © 2001-2021 Matronics. All Rights Reserved.
