Zenith CruZer & Sonex Logs
Date:  2-28-2019
Manual Reference:  C75-CA-3
Brief Description:  Finish rudder pedal fixtures / deburr / fwd side c
Measured and positioned angles to hold the brake master cylinders. Had to file-down the upper curve of all 4 pcs as they were interfering with the cylinder attach points. Clamped in place, then up-drilled to #20 for A5 rivets. Cleaned up the pieces; removed red marker lines and de-labeled the parts.
Deburred several fuselage L-angle pieces.
Up-drilled and deburred 5 of the 6 L-angle / forward angle assemblies that mount on the forward side skins, providing rigidity.
brake master cylinders sitting in position
Me up-drilling fwd side angles
Copyright © 2001-2021 Matronics. All Rights Reserved.
