Zenith CruZer & Sonex Logs
Date:  1-15-2019
Number of Hours:  1.10
Manual Reference:  C75-FA-6
Brief Description:  Drill cabin frame
A lot of time for little accomplishment.
Drilling steel tubing is not as easy as aluminum!
Each corner of the cabin frame comes with one hole pre-drilled by Zenith.
The builder must then drill the remaining 8 holes in each corner, then up-drill to #20 with an intermediate stop at #30. Went thru 2 drill bits so far, and still have the upper corners to drill!
first holes drilled to #40
final holes up to #20
