Zenith CruZer & Sonex Logs
750 Cruzer
C75-SSO-2
Finish installing left seat base
Drilled locations on seat base that were previously marked.
Placed in location in fuselage; drilled thru into seat supports SSO-1 and SSO-2.
Up-drilled most holes to #20; up-drilled 4 mounting spots for seat adjuster rails to 3/8".
Located and drilled mounting holes for 4 nutplates.
Chamfered holes and riveted 4 nutplates to seat supports. Test-fit adjuster rails.
seat base drilled and nutplatest installed
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
