Zenith CruZer & Sonex Logs
Date:  1-12-2019
Number of Hours:  1.70
Manual Reference:  C75-SSO-2
Brief Description:  Finish installing left seat base
Drilled locations on seat base that were previously marked.
Placed in location in fuselage; drilled thru into seat supports SSO-1 and SSO-2.
Up-drilled most holes to #20; up-drilled 4 mounting spots for seat adjuster rails to 3/8".
Located and drilled mounting holes for 4 nutplates.
Chamfered holes and riveted 4 nutplates to seat supports. Test-fit adjuster rails.
seat base drilled and nutplatest installed
