Brief Description: Add L-angles to supports & initial seat base insta
Continued initial setup of left fuselage side. Ensured plumb on forward attach point for the seat base; clamped and drilled-thru L-angles and cleco'd in place.
Installed forward seat support for sliding seat option. Outboard location pre-determined by kit components pre-drilled at factory. Ensured distances were the same and plumb on the inboard side; fabricated L-angle, pilot drilled, then back-drilled into side armrest and seat support to lock in place.
Fabricated L-angle for inboard angle of rear seat support; drilled pilot holes, then clamped to the support and armrest and back-drilled thru and cleco'd.
Began fitment of left seat base; as with the right side, had to trim a bit off the outboard edge where it butted against the fuselage side.
