Zenith CruZer & Sonex Logs
Date:  1-6-2019
Number of Hours:  1.10
Manual Reference:  C75-CA-2
Brief Description:  Remove powder coating - rudder pedals
No pics.
I had the rudder pedals powder coated just before Thanksgiving, and since they mount to the forward fuselage, and since I'm working on the forward fuselage, I decided to clean them up post-coating.
The powder coating shop masked-off areas I knew needed to be bare metal (to fit in flanges etc.) but I did not specify for them to mask enough of the mounting lugs. The masked part came off easily, but the other - hoo boy. That coating is tough stuff.
Removed powder coating from both inner and outer bearing surfaces on both pedal assemblies.
Copyright © 2001-2021 Matronics. All Rights Reserved.
