Zenith CruZer & Sonex Logs
Date:  11-7-2018
Number of Hours:  2.70
Manual Reference:  C75-FA-2
Brief Description:  Wrapped up right side, started top panel
Deburred right wing components C75-F-3-1 and F-4-1. Cleco'd into position to provide rigidity at the front of the skin during manipulation.
Marked and drilled the front vertical post (F-4-1) for the 1/8" thick L angle doubler. Up-drilled to #20. Riveted the two parts.
Moved R wing panel to the wing cradle.
Unwrapped the top skin; deburred all edges and all holes.
Deburred the 7 vertical and diagonal L-angle stiffeners and cleco'd into position.
Copyright © 2001-2021 Matronics. All Rights Reserved.
