Brief Description: Bolt in strut fitting; check flaperon bracket dist
No pics.
Installed the 3 AN4 bolts to hold the stut fitting to the inner surface of the wing. Difficult on the last lower bolt; not enough room to put a box wrench on it (at least if you want to get it off!), and hard to position both a nut and washer in a blind fashion. After several attempts, success.
Cleco'd the upper trailing edge in place on the aft spar in order to check the flaperon attach bracket to trailing edge spacing. I have some spacting issues so will call Zenith in the AM; tried different combinations of cleco spacing and had to re-install the brackets since I put some in the wrong position.
