Zenith CruZer & Sonex Logs
Date:  5-8-2018
Number of Hours:  1.90
Manual Reference:  C75-KA-2
Brief Description:  Finish tank install; wiring, plumbing
Removed the top tank cover and tank. Removed a layer of cork from all left side (inner) surfaces, and added a new strip on the right side to each location.
Spent some time "finessing" the fit of the tank so that the filler cap, fuel outlet, fuel sump, and vent tube all aligned properly to the ribs, skins, and top. This took several in-and-out attempts with the tank. Finally obtained a good fit where everything fits just right.
Installed the top skin, applied fuel sealer to the filler neck and fuel outlet fitting, and installed both. Still have to secure the fuel line & fuel sender wire securely, but just about finished!
Tank grounded to rib and sender
Cap fits great; flush
fuel line installed and routed
