Zenith CruZer & Sonex Logs
Date:  3-6-2018
Number of Hours:  0.50
Manual Reference:  C75-AA-1
Brief Description:  Install Left Outer Flaperon ABS tip
Sorry; no pics. The last item to be done on the left outer flaperon was to install the ABS plastic tip fairing. Trimmed manufacturing flash, marked a line 10 mm from the edge to guide correct installation depth, then drill and rivet. Riveted by hand; when I did the right side tip, the pneumatic riveter pulled pretty hard and makes it seem like 2 rivets pulled thru. Will remove that tip and install washers for backup later down the road.
Copyright © 2001-2021 Matronics. All Rights Reserved.
