Zenith CruZer & Sonex Logs
Date:  2-7-2018
Number of Hours:  1.70
Manual Reference:  C75-AA-1
Brief Description:  Rivet inboard right side flaperon / trial fit skin
Relatively straight-foward. I had previously cleco'd the ribs in place and had fabricated the flaperon pivot/mount brackets out of 1/8" extrusion.
All of the ribs had to be up-drilled to #20 where they mount on the spar; they came from the factory only to size 30. Riveted the ribs and two nose ribs. The inboard end rib does not get riveted at this time; a bracket has to be installed before this is done.
Clamped the pivot/mount brackets and drilled thru the spar & ribs at #40. Updrilled to #30, then finally to #20. Riveted.
Cleaned up the bench a bit and test-fit the skeleton assembly to the skin. I have to check the instructions to determine if upper or lower is riveted first; I *think* the bottom is.
Detail of control pivot
Completed skeleton
Completed skeleton
trial fit of skin; lower side
Copyright © 2001-2021 Matronics. All Rights Reserved.
