Zenith CruZer & Sonex Logs
Date:  2-3-2018
Number of Hours:  1.80
Manual Reference:  C75-TA-2
Brief Description:  Check Alignment / Rivet Stab Hinge / Start Flapero
We're having our enclosed patio completely redone, so not much time to do airplane stuff.
Another builder asked if I had any twist issues with my elevator & horizontal stabilizer, and, while I thought I had everything checked-out, I decided to pair them up again and recheck, especially since I had riveted the elevator since they were last paired.
Fortunately, both ends lined up just fine, so all is good. Unfortunately, I then noticed that I had not riveted the hinge position on the horizontal stab. Riveted all those holes.
Dug thru the parts to find flaperon parts. I decided to start with the right side inner flaperon, mostly because it was the same one they used in the Homebuilt Help video. Since there's 4 flaperons, there's a bunch of ribs, nose ribs, and end ribs. Sorted thru the parts and positioned them. Next task will be to debur and remove labels.
All riveted
All riveted
Right Inner Flaperon Parts
