Brief Description: Remove rods; test fit crank in case; bag lifters
Removed cotter pins and removed rod bolts; removed connecting rods. Removed crankshaft from engine stand. Installed in one case half; just wanted to check thrust bearing clearance (.015").
Removed lifter bodies and hydraulic units. Bagged according to cylinder number and whether intake or exhaust.
