Started the avionics harness build. I am stuck finishing the power system as I need the leads from the various avionics to the CB panel before I can close that area up. So the emphasis will be the avionics harness for now. Got a slow start trying to decypher the wiring drawing from Stein and quickly realized I need to order more wire and solder sleeves and shrink wrap. I'll jump around building sections until I get the needed supplies. Jumped in with the Autopilot wiring.
