Finished the ELT wiring in the rear with the DIN plug wiring. The Vans harness has the wires already in place but the wires that connect to the ELT's DIN plug have the maddening Micro Molex pins which fit on the connector pins but they are loose so I just cut them off and soldered directly to the pins. The telephone cable is also pre wired back in the empennage kit but it looks like it's going to be slighty short at the panel end. I'll need to exted it by a couple of feet. Installed the remote control for the ELT into the panel cut out. Finished wiring the circuit breaker panel. Looks like I need to order a new breaker to replace one that I need to doube up output leads for the GTN navigator.
