More wiring and head scratching, pretty typical day of wiring. Wired the GAD-27, this will be mounted to the center tunnel plate behind the dash and will need to be completely removable so there are connectors to the main wiring harness. NOTE - udated to reduce number of connectors later in the build by going to a 28 pin vs several 9 pin ones.
