Reassembled the tail section to get the tail section fiberglass fairing fit and trimmed. It all fits well and was a straight forward process, just remember don't trim to the trim lines until after the screw holes are final drilled just in case there is some shifting needed and you can maintain a safe edge margin based on the hole not the trim line. Trimmed and sanded and will get painted along with the cowling and apinner parts.
