Chris's RV-14A Site
Date:  12-5-2017
Number of Hours:  1.00
Brief Description:  Remove oil plug
Removed the seal from the crankshaft for the constant speed prop. This cap needs to be removed in order for oil to flow into the prop hub and change prop pitch. I drilled a #12 hole and used an auto body slide hammer to pop the seal out. Cleaned out the debris and it's good to go.
Drill #12 hole
Drill #12 hole
Screw in slide hammer
seal is gone
seal is gone
