Spent today shamelessly plagerizing other builders' designs for a fuselage rotisserie. Picked up a 1000 lb capacity engine stand from Harbor Freight and built the adapter plate. It fits niceley and is very sturdy ( heavy) since it's mostly 2 x4 and 3/4" outdoor plywood. Once the tail gets attached to the fuselage I will hang it from the rotisserie with the tail also supported. This stand is going to stay attached through painting of the fuselage probably in the Spring.
