Attached the left fuel tank, it all went well and everything lined up with no issues. the skin gaps were very nice and no gaps or buckling. Got it all torqued down. Got some more wiring done, I think It would have been easier to just use the AeroLed setup that the wire harness is made to connect to as I need to run separate shielded cable for the Flyleds setup and remove pins in the molex at the ends to connect these new wires.
