Brief Description: Finished left wing rib attachment
Completed riveting the ribs to the left main spar then moved on to trial fitting the rear spar then assembling the rear spar. I didn't complete the inboard doublers as they need to be reamed to final size 3/8" and I am waiting on a reamer. I want to ream the holes prior to attaching the doublers to the rear spar as it would be hard to manipulate a 10 foot spar to get the doublers onto the drill press.
Trial fitting rear spar
You can rivet some parts prior to attaching the spar to the ribs
Right and left rear spars with aileron brackets attached
