Brief Description: Beginning to work on the elevators
Starting to work on the elevators and the trim tab which is on the left elevator half. Lots of detail work here with the hinge and the foam ribs that will need to be glued in with proseal. Lots of places to make mistakes with the left and right elevator halves not being exactly the same.
Mocking up elevator assembly
Foam ribs for the elevators and trim tab to be cut
