Brief Description: Fabricating a new baffle bracket
OK I have a baffel kit designed fora currnet modle IO-540- D4A5 but I have a C4B5. As a resort the baffel supports don't match up in every instance. As a result, I had to improvise as in the case of the right rear baffel support bracket. This was a trial and error process (emphasis on the error part) to get the angles on the bracket right.
