Primed both torque tubes. After they dried, sanded both ends to get them to fit inside the collars. After some trial and error, finally got them in and bolted up. Installed them on the wings and set the ailerons to neutral. Had to order new nuts (364's low proflie nuts) to replacethe 365's because I could not get any threads to show past the nut no matter what I did.
