Brief Description: Fabricated trim cable and bellcrank brackets
Fabricated the bellcrank and trim cable attach brackets from supplied aluminum angle. I then deburred and final drilled the servo spacer and moved on to CSK'ing the required holes on the spacer and screwed it up. Even though I had clearly marked the side that needed to be CSK'd, I mangaed to begin CSKing the wrong side, trashing the part. So I have to order a new one from Van's--a $4 part, but frustrating nevertheless.
