Brief Description: Temp foam rib for the VS fairing
OK, it's been a few months. In that time I've been dabbling with my VS fairing. Basically I've been putting if off as of all my fairings, this one fits the worst and will require quite a bit of build up to match the contours of the VS (not my fault this time--I honestly think may it's fairing from a -7 or -8). So I've been sanding away at it to get the gel coat off. Today I decided to work on the temp foam rib. So I cut a piece of rigid foam and sanded it to shape. I then glued it in and covered it with PVA as a mold release.
