TODD'S WEB SITE
Date:  1-13-2008
Number of Hours:  3.00
Manual Reference:  Sec 9 - Elevators
Brief Description:  Prepped and primed trim tab parts
I restocked all of my chemicals (Sanchem 6100-CC parts A, B, and C plus more AFS primer) over the past week and picked up the last item I needed (distilled water) last night. So this morning I prepped the trim tab parts by taping off the areas where the foam ribs will get pro-sealed in, washing everything in Dawn, then scrubbed with a maroon Scotch-Brite pad and part C. Rinsed with distilled water then treated with a solution of equal parts of A and B. Rinsed with tap water and allowed the parts to dry. Then shot the AFS primer (smoke gray). I had to relearn all of the steps a little as I was rusty, but it came back in short order. For this small amount of parts it still took quite a bit ot time which included set-up.
Parts in the process of being prim
