Brief Description: Riveted root and tip ribs in-place
Riveted gussets in-place and finished up the root ribs. I had the kids cme down and help hold the skin back out of the way. I then moved on to the tip ribs. Getting the rib/spar flanges riveted was a bit of pain. I pretty much butchered the right side, drilled a couple of them out and reshot them. I'm not real happy with the end results, but any further attempt to fix them will only result in making the rivets worse. For some reason the left side ones came out fine. I guess practice makes perfect.
