Brief Description: Continued riveting tip rib assembly to elevators
Riveted the tip assemblies to the skins. There were 2 rivets on the top skin that had to be bucked because they were interior to the spar and rib. I taped them in place and then flipped the whole elevator over, pulled the skin back and then shot the rivets. The same 2 rivets on the bottom skins got filled with blind rivets. One of those didn't sit flush so I drilled it out and then replaced it.
