TODD'S WEB SITE
Date:  9-2-2013
Number of Hours:  1.00
Manual Reference:  Sec 47
Brief Description:  Completed oil acess door
To complete the door. I needed to reinforce it and add the latching mechanism. To reinforce it I simply added a bit of foam that I then glassed over (the tan colored "T" in the pics). I opted to go with Hartwell latches instead of camlocs. I cut out slots for the latches and then riveted them to door. I also added some flox reinforcement to the cowl where the latches contact the underside of the cowl.
Door underside
Door underside
Door from the outside
Hidden hinge is spring loaded
