Brief Description: Installing the camloc support strips
The top, side, and bottom camloc support strips get riveted on to the fuse vice the cowl. It wnet on realtily easliy -- I squeezed the rivets everwhere except one rivet on each side by the top engine mount bolts. At both those spots I had to use blind rivets as there was no clearance to use a solid and get a rivet set or bucking bar on the rivet shank.
