TODD'S WEB SITE
Date:  3-16-2013
Number of Hours:  1.00
Manual Reference:  Sec 12 - Emp
Brief Description:  Pitch trim servo
Now that the HS and elevators are on, it’s time to install the pitch trim. The first thing I did was to install a 9-pin d-sub connector on the servo wires for easier connection to the wiring harness later on. I put the servo tray in the tailcone and began the process of snaking the two cables through the HS and elevators back to the trim tabs. I quickly discovered that A. I really needed a pull string to make that happen, and B. it would have been easier to install a pull string without the VS and elevators on. So decision time – pull the VS and elevators or figure out a way to get a pull string through the structure. Because of the pain in the ass the both were to install, I opted on the latter. It turns out the only way I could get this to work was to use a two pronged approach. Basically, I wasn’t able to run a stiff wire all the way through from one end to the other. No matter how hard I tried I couldn’t manipulate the wire to get through all of the grommets in the HS. But what I could do was get it halfway through from either side. So that’s what I did – I ran wires from both the elevator access and from forward side of the HS that met up in the middle of the HS that I could reach. I then tied them together and was then able pull a continuous length of pull string from the front of the HS to the trim tab access hole in the bottom of the elevators. I then connected the string to the trim cables and gently pulled them through the HS and elevator structure until they emerged on the trailing edge. It was a piece of cake to install the rod ends and hook up the trim tabs and verify their movement.
Trim cable routing
Trim cable routing
Pitch trim servo
Pitch trim servo
Right trim tab
Right trim tab
