Brief Description: Removed plastic from rivet lines
I have decided not to prime the winfg skins if I can help it. Soooo, that means leaving the plastic on as long as possible, which inturn means using a soldering iron and straight edge to melt the rivet lines. A little tedious, but way easier than priming.
