Arts Web Site
Date:  11-23-2022
Number of Hours:  1.50
Brief Description:  Fab TE and Dimple Spar
I assembled the aileron with all components to check the fit. The TE was marked and cut to length. When you cut the TE you have one end that is flat and another that has a lightening hole. I oriented the TE so that the end cut thru the hole was on the inboard side and not so noticable.
Using the Cleaveland jig for TE countersinking
