Arts Web Site
RV-14A
Dimpling nose ribs, main ribs, and spar
I started dimpling the various parts. The primer I used isn't nearly as good as the Akzo primer. About 20% of the holes I dimpled had the primer crack and flake away.
Dimpling nose rib
Rod end subassemblies completed
RV-14A Home
666
06-Vertical Stab
07-Rudder
07-Rudder #2
08-Horiz. Stab
09-Elevator
10-Aft Fuselage
13-Main Spar
17-OB Leading Edge
18-Fuel Tank
21-Flap
22-Aileron
25
71
EAA Tech Counselor
EAA Tech Counselor V
Lessons Learned
Research
Shop Setup
Sub-kit Delivery
Training
Zip Tips
