Brief Description: Install Nutplates on LHS Lower Spar Flange
Tonight was a continuation of yesterday's activities, this time on the lower flange. Instead of doing each nutplate individually, I decided to cleco and screw all of them in place then just go down the line with the pneumatic squeezer. It worked well, but holding that 7 lb squeezer for a lot of rivets was a bit tiring. I'm not sure it was any faster either. In any case I'm done with the flange fasteners in the LHS spar.
I still have to install seven nutplates on the web, but I ran out of daylight and energy at the same time.
I ordered a single flute #30 countersink from Cleaveland and it will arriver later in the week. I'm going to hold off countersinking the screw holes until this weekend. I need to do the C/S and Alodine application in one session.
I tried an assembly line process this time. Cleco and screw all nutplates first, then rivet.
The smaller nutplates are for access panel screws. The larger are for the fuel tank screws.
All flange nutplates are complete on the LHS spar.
